converting from lm90 to cimplicity
rhartong
Apr 2004
illinois
I recently did the conversion on some of our equipment from LM90 to Cimplicity ME, with no problems...until now.
This is what I'm getting when I verify equality....
---------- Verifying ----------
---------- Hardware Configuration ----------
Verifying: MASTER HARDWARE CHECKSUM EQUAL
Verifying: CONFIG VERSION EQUAL
Verifying: SNP ID EQUAL
Verifying: RACK SLOT CONFIG EQUAL
Verifying: I/0 CONFIG EQUAL
---------- Program Logic ----------
Verifying: _MAIN.dec EQUAL
Verifying: _MAIN.pdt NOT EQUAL
---------- Initial/Forced Values ----------
Verifying: _MAIN Ref Table - %Q EQUAL
Verifying: _MAIN Ref Table - %I EQUAL
Verifying: _MAIN Ref Table - %AQ EQUAL
Verifying: _MAIN Ref Table - %AI EQUAL
Verifying: _MAIN Ref Table - %M EQUAL
Verifying: _MAIN Ref Table - %R EQUAL
Verifying: _MAIN Ref Table - %G EQUAL
---------- Summary of Equality ----------
Hardware Configuration - EQUAL
Program Logic - NOT EQUAL
Initial/Forced Values - EQUAL
---------- Verify with PLC completed. ----------
Disconnecting...
Disconnected from the device
Compare has completed
Everything is equal except for the _MAIN.pdt
Has anyone seen this? Is there something I can do to get past it? Currently, I can not connect to the PLC on this machine.
Thanks.....
Once I convert from LM90 to Proficy, is that program backward compatible as well? If so, how do you get around that? Thank you
38
12,726
We have an old machine with a GE Fanuc 90-30. We need to reload the program, I have an original on floppy that was made using LM90-30 V4. Our old...
2,997
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
212
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
127
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
333
