conveyer vs box speed calculations??
mordred
Mar 2004
Red Deer
1,892
Does anyone have the formulas to calculate the number of boxes vs conveyer belt speeds? I have 5 automatic conveyer systems that according to the installation contracts were designed to supply 22 boxes per minute. I need to speed them up to allow for 24 boxes per minute.
So assuming the size of your box is 200mm.
22 (boxes in a minute) x 200 = 4400mm / 1000 = 4.4 metres per minute.
So assuming the gap in between each box is 100mm then
22 (gaps) x 100 = 2200mm / 100 = 2.2m/m
So the total speed for 22 boxes per minute + gaps is 6.6m/m
Going by the same figures 24 boxes per minute would be 7.0m/m
Hope this helps
Could it be this simple...?
24 / 22 = 1.091
Current speed for 22 boxes/min. x 1.091 = speed required for 24 boxes/min.
beerchug
-Eric
please check 24*760=18240/1000=18.24 m/m
24*610=14640=14.640 m/m
total speed = 18.24+14.640=32.88 m/m
32.88 metres=107.88 feet/min
Is this correct?
number of cases*length of case(mm)/1000=no space rate (metres)
number of cases*gap between each case(mm)/1000=rate of gaps (metres)
total belt rate metres/min=no space rate+rate of gaps
Unfortunately I cannot do a direct ratio calculation due to design changes after installation. So I would have to calculate actual speed vs case rates
Need advice! We have a powder coat line controlled by 4 DL06's networked together. Each unit controls a segment of the process, the conveyor, the...
2,238
hello all brand new to this forum and also new to PLC programming. here's my dilemma, I am installing a PLC and a VFD Drive unit into a conveyor...
114
21,082
Hello,I need ladder logic for SIEMENS PLC. There is a conveyer belt on which similar kind of bottles are travelling. At the end, the conveyer belt...
1,919
Programming my first conveyer and what I have to work with is a conveyer with one motor and four sensors one sensor where the pallet gets loaded...
7,584
any info to match 2 conveyers to an encoder. Conveyer 1 would lead 2. Encoder scaled and outputed to 2 (4-20ma).To syncronize the analog out...
2,502
