cp 5/05 to cp 5/04 through 1761ENI messaging
plc2010
Feb 2010
d
I am new to this forum and I would like to say hello to everybody.I could find in here usefull information, so I thought to join.
I have an issue about messaging between a cp 5/05 and cp 5/04 through 1761 ENI.
My settings are as follows:
1761ENI
IP 010.010.001.040
mask 255.255.0.0
gateway 000.000.000.000
message routing:
destn. 1 101 010.010.001.201
I can communicate with cp5/04 through 1761ENI with a PC.
So I guess everything is fine between cp5/04 and ENI.
CP05/5 MSG instruction in the program:
peer-to-peer
read
target: 500cpu
local/remote: local
N17:0
MSG setup screen:
500CPU read
data table address: N17:0
sizen elements:1
channel: 1
For target device:
message timeout: 0 (cannot modify)
data table address:N10:0
ethernet IP Address: 10.10.1.40
local/remote: local
multihop:No
I cannot read from cp5/04 (in the first step).
If anyone can see the problem or have suggestions,
Thank you
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
230
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
56
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
120
6FX5002-2CD24-1GR0 Via Siemens Sinamics SINAMICS S120 are cuted. I got 1 project that they relocating old Machine to install to new location. Mut...
57
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
961
