CP1413 configuration
srik
Sep 2005
hyderabad
104
We have an opearting station with COROS LS-B HMI.
THe hard disk has failed.So I loaded the COROS-LS-B in another PC with win98 OS.
But it is now showing error" CP not working or Interrupt not working"
what is this interrupt?
I changed the interrupt in COROSLSB SET. Then it is showing " Interrupt can not be reserved"
how to resolve the problem?
Hi We currently have a small network of desktop PC's that connect to some S5 PLCs via CP1413 cards and the H1 network. Does anybody have...
1,994
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
57
Hello I have a sensor that I read data with IO-LINK but I don't know how to get my data. I see that I have two modes : Process data Map0 and Map...
61
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
99
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
