I am using CPU315-2DP.It was working fine till the touchscreen connected to the MPI port got spoiled.The internal fuse of the touchscreen had blown.The CPU is connected to 10 ET200m by the DP port.there is also an ethernet card(CP343-1) connected on slot 6 of the rack.
there is a 16pt di and 16pt do connected at slot 4 & 5 of the rack.
the problem now is the ethernet when connected to the bus the CPU will go in stop mode.IF we remove the ethernet card from the bus the CPU works fine.
When the CPU goes in Stop mode it shows this error in the diagnostic buffer:
parameter assisgnment error assigning parameters to modules(not on P bus,cancel download)
no revelance for user:SDB number:1002
DP master affected in rack 0 and slot 6
Station number:0,slot number:10
Operating mode:Stop(internal)
Internal error:Incoming event
We changed the position of the ethernet on the rack still same problem.
The ethernet is in run mode.Its still not connected to the 3rd party software.
We r just hooking it to our LAN network.
Previously we could download the program through the ethernet port connected to the LAN.Now we cant download.It give errors.
Do let me know how to solve this problem
Regards
Annie
Regards
Annie
