cpu315 rx3i ge, etm001, ion 7550 schneider
milo_IDT
Jul 2012
Santiago
23
hello,
device can be read via Modbus ION7550 with a GE RX3i PLC, do not allow me to place a read address above 32767, as I can do to extend that value
:sick::sick::sick::sick::sick::sick::sick::sick::sick::sick::sick:
hello,
Proficy ME lets me use any valid value I want for the assigned "Data Type". Exactly where are you attempting to use this "Unsigned Integer" value within PME?
Is it in Logic, a Parameter for a Function, Configuration of a module?
Here is a screen shot that may help: ( For reference only, the value 33721 really should be 0 here.)
I am using Proficy ME 7.50 SIM3 here.
hello,
That is, I need to put the address I have to point in that direction and ION7550 is 40150, then to set the value and throws an error compiling, but apparently achieved by placing the block UINT do.
Now try, then you commented, thanks
I want to realize the communication S7 and pc by cable profibus or mpi I want to know the steps to that allows me to do it
1,272
good day everyone. right now i troubleshoot a STACKER MACHINE. the fault in the PLC CPU315-2 pn/dp is BF1 and SM fault. I check all the...
2,070
Hello , I have the classical configuration of CPU315-2DP + 5 * ET200 , just long time did not work on this configuration , the switch of Profibus...
2,641
Dear Sirs, I had a problem with CP 343-1 with CPU315-2DP.I had newly add the CP343-1 Ethernet module to the hardware to allow me to access this...
2,639
Hello Can any body help me for communicating Deltav and PLC(Cpu 315-2DP)without cp342. How am I doing this configuration in PLC. Please help me.:hmmm:
1,064
