Current limits?
Thomas
Mar 2003
167
Hello all,
This is not precisely a plc question but...
I have a pair of small (~0.5 hp) split phase motors on a machine. I want to stop them slightly before the rotors are locked. (Currently we are just using run time as the limit.)
I would like to control based on torque or current. Does anyone know of a device that provides a (reliable) device with a discrete output and a precisely adjustable current trip setting?
Thanks,
Thomas
Check out products made by Symcom, Inc. in Rapid City SD. This is exactly their mainstream line of business.
They make a variety of motor monitoring products but the most well-known is "MotorSaver" and "PumpSaver".
Tom and Dick: Thanks for the info these look like they might work.
RoTaTech: If you find anything, I'll keep an eye on this thread.
Again, thanks all.
Thomas
Thomas said:
Hello all,
I'd suggest putting variable frequency drives on the motors. With modern IGBT-based drives, it is quite possible to have speed ranges from -150% to +150%, with 100%(+) torque throughout the range. You can even run them at zero speed with 100%(+) torque.
You can do internet searches, but there are probably 25 decent manufacturers that can supply these. Vacon, Siemens, ABB, and AB are four that come immediately to mind. At least three of these can be run in torque-control mode. All of them have the capability to be precisely current-limited.
Good luck.
Don, these are single phase motors. Forget frequency drives. Except for extremely narrow obscure circumstances, variable frequency is for three phase motors only.
Today I was working on my project for school and we were using a power supply with 24V and we accidentally had the current at 0.9A. We heard a pop...
558
Hi all, I have been working on a project that requires me to measure the current across a 90 VDC motor of a medical device (similar to an...
26
1,572
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
675
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
343
VFD is not tripping at higher current , resulting in motor failure . VFD Model : Make - KEB Type - H6- 10H6BBBB-21B0
513
