CX9010 Beginner facing errors
Ivan.K.
May 2015
Stupava
Good day to you all,
I have been tasked at work to control MOCVD deposition apparatus by the means of an PLC from beckhoff(CX9101-0101). I have been reading thought the manuals and going step by step to program it with twincat 2. However every time I wish to boot the PLC into run mode I get an error:
Type Server
(Port) Timestamp Message
Error TcSysSrv (10000) 24.4.2015 9:57:03 48 ms Error 9811070c occured loading
the configuration of the TCPLCW32.dll server.
Error TCPLC (801) 24.4.2015 9:57:03 46 ms PLC: Error (1804 (0x70c)) loading
retain data of run time system 1. Run time stopped
Error TCPLC (800) 24.4.2015 9:57:03 43 ms Boot data not found (file: TCPLC_R_1)
Warning TCPLC (801) 24.4.2015 9:57:03 31 ms PLC: Warning (1804 (0x70c)) reading
permanent data of run time system 1 failed
Error TCPLC (800) 24.4.2015 9:57:03 29 ms Boot data not found (file: TCPLC_T_1)
Hint TcSysSrv (10000) 24.4.2015 9:57:02 19 ms TwinCAT System Restart initiated
from AmsNetId: 127.255.255.1.1.1 port 32779.
This means that I cannot even try the simplest program I have made for it, which just cycles one relay on and off. Any help would be greatly appreciated.
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
251
So to start off: I have no experience with PLC's, but I'm good at figuring stuff out, but I need some help to know if my PLC is just dead in the...
115
Dear all, First of all thanks for letting me join this forum. I just need some help in one of my programming exercises. Being a beginner...
611
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,270
First time poster here so long story short i built my own trainer at work so i could toy around with various things and test things and learn...
25
2,152
