Cx9020 + el6224
Luchian
Oct 2016
Bucharest
19
Hi guys,
I have a PLC from Beckhoff (CX9020) and an IO Link module EL6224. I'm trying to read some data from a photoelectric senzor(IFM http://www.ifm.com/products/us/ds/O6H200.htm) or from siplus cms2000 vib-sensor s01 (Siemens). Well..the problem is that when I try to scan devices in Twincat 3, it doesn't find anything for no port. And I know that I have an alternative like introducing manually the details about my sensor. The problem si that I can't find those details...
I attached two photos.
Thank you !
Hi guys, I have a little situation here. I try to connect a modbus RTU device to my CX9020 using EL6021. I did some research and I found out that...
5,937
Hi guys, I have a CX9020 Plc and some modules and I want to connect my PLC to CP6066 which is a HMI from Beckhoff. This HMI uses Twincat 2.11, my...
2,951
Hi fellow programmers ! I just got put onto programming a Beckhoff cx9020 PLC with twincat 3. I have run into a problem creating and opening files...
3,141
At our company we are using Beckhoff a lot of cx9010 en cx9020. On one of the cx9020, after the scan devices is done in the system manager, there...
3,353
Dear Members: I am new at Twincat PLC System. I am working on a project. I have connected CX9020 with a PSI-9750 high voltage power supply via...
1,801
