Danish Technical translation from drawings :) Anyone !
504bloke
Jan 2005
Down South
2,721
Have some drawings that i need to know some parts of, the machine is danish and the drawings i have are either danish or possibly german, here is the text :)
The text has spaces between it to differentiate
This is next to an EStop symbol
Betjening
NoDSTOP (The o has a slash through it and is in caps)
This is next to what looks like a safety symbol possibly a guard switch
INDBLASNING (The A is sort of italicised)
LAGESWITCH NR.1 (the A has a small symbol above it)
A reset switch on a sick light curtain
Reset
Gitter
Indlob (The o has a slash through it)
Reset
Gitter
Udlob (The o has a slash through it)
Nodstopknap (The first o has a slash through it)
Kolezone (The first o has a slash through it)
WIRENOSTOP (The first O has a slash through it)
Kolenzone (The first o has a slash through it)
This is next to a double pole contactors contacts
dorkontakt (The first o has a slash through it)
udlob (The first o has a slash through it)
indlob (The first o has a slash through it)
This is going to a robot panel from safety circuits
NodstopKreds (The first o has a slash through it)
I Robotstyring
This is going from the robot panel through the safety circuits
Nodstop (The first o has a slash through it)
Robot
This is going from the robot panel to reset the safety circuits
Reset
Robotskab
From a conveyor panel to the robot (volt free)
Klarsignal
Robot
From robot going to speed input of ac drive (presume speed control)
Conveyor
Hastighed
Within robot something to do with start (Push Button)?
Manual
Extern
Startsignal
Pa Robot (the a has a small symbol above it)
Within robot electronic output something to do with start?
Manual
Extern
Startsignal
Beckhoff
Interlocked (series) with speed signal to conveyor.
Conveyor
Lav
Hastighed
All help appreciated :) !
hey 504bloke
just use http://translate.google.com/, i would have done them myself, but im about to go to bed, but if there is any you cant do il translate them for you tomorrow.
here are the symbols you will need to translate it correctly
1. æ
2. ø
3. å
regards
the dane
Thanks for the replies
I have used the translate online before, but find it not very good for technical words, it either cannot do them or gets them completely wrong, so i posted here as the experts in this language would give me a better translation.
There may be some implied "at", "on" and "of" that I cannot see from the short text snippets.
Betjening NØDSTOP
(operation E-STOP)
INDBLÆSNING LÅGESWITCH NR.1
(BLOW-IN DOOR SWITCH No.1)
Reset Gitter Indløb
(reset grate (?) inlet)
Reset Gitter Udløb
(reset grate (?) outlet)
Nødstopknap Kølezone
(E-stop button Cooling zone)
WIRENØDSTOP Kølezone
(lanier E-stop cooling zone)
dørkontakt udløb
(door switch outlet)
dørkontakt indløb
(door switch inlet)
NødstopKreds I Robotstyring
(Emegergency stop in robot control system)
Nødstop Robot (E-Stop robot)
Reset Nødstop Robotskab
(Reset E-Stop robot control panel)
Klarsignal Robot
(Ready signal robot)
Conveyor Hastighed
(Conveyor speed)
Manual Extern Startsignal på Robot
(Manual external start signal on robot)
Manual Extern Startsignal Beckhoff
(Manual external start signal Beckhoff (?))
Conveyor Lav Hastighed
(Conveyor low speed)
Jesper
Thanks again for your translation, worked very well, flawless.
I wonder if you could translate the following
1.Looks like a remote (volt free) reset for the EStop Module
Fordertechnik (the first o has 2 dots over it)
2. Looks like a safty circuit volt free output
Steuerschrank B&M (B&M are the machine makers)
Can anyone recommend some Danish automation resources were I can find proper automation translations? Goole translate has its limitations...
2,452
Work instruction. Hey seasoned vets, I have to make some work instruction for a couple things and I’m just out of school I was wondering if...
997
Hi Guy, some times i receive this message in my PV1000: 637 Communication Driver has FAULTED -contact technical support. after there is no...
3,880
Below are the few details for your reference: B&R PLC Module 2005 CPU – CP152 with APM (Application Memory) Module ME Power Supply – PS477...
1,564
An automation system having a dedicated PLC connected to feedback potentiometer supplied via 0-10V, an added automated system based on another PLC...
18
4,244
