DB100 = integervalue ? Step 7 question
userxyz
May 2002
any
2,768
I am doing something like this in my stl code:
L #DB_DATA
DB_DATA is an in of an FC and is Data Type Block_DB
If u entered 100, then DB_DATA is DB100
But now I want to have the DB number in an integer value...
I want:
L #DB_DATA
L MW5
If u entered 100 in DB_DATA, then I want to see 100 as integer value in MW5...
can this be done ?
ddd
L D[AR2 said:
Do you mean something like this ?
Code:
	 OPN #DB_DATA
	 L	 DBNO
	 T	 MW	 5
Code:
	 OPN #DB_DATA
	 L	 DBNO
	 T	 MW	 5
Do as above, ensure DBnr is an integer, then before the block call
L DBNO
T DBnr
Well, you guys are right, DBNO is the way to go, sorry for my misunderstanding.
It works,
Thanks guys
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
192
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
258
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
344
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
558
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
694
