DC current to 0-10V
MrQ
Feb 2005
236
Hello,
I need to measure the current(0-30A) from a 24V DC powersuply and read it in a 0-10V AI on my PLC. It would be neat to use a unit that is like a clamp meter. But maybe there are better ways. Any suggestions?
I am also to read the voltage (0-26V) from the supply to a 0-10V AI. I could of course use voltage dividing via two resistors but something integrated with the current measurement as one unit would really be nice. Any suggestions?
www.ohiosemitronics.com
For DC current you can't use a donut style current transformer but Ohio Semitronics does have hall effect sensors which look like a CT donut.
edit: oops, just saw where you were from. Oh well, OSI also sells some European made sensors so go ahead and take a look, it might point you in a direction.
Hello,
phoenix contact has what you need.
Have you ruled out using a simple shunt resistor?
Something like 0.01 Ohms to give 10 mV per amp.
Last time I looked proper shunt resistors were still available.
If you just need a rough number try measuring mV drop across a couple of feet of #12 wire.
Hall effect sensors will work of course, just offering another option.
Roy
here are the phoenix contact part numbers
current transmitter
mcr-s-10-50-ui-dci
voltage transmitter
mini-mcr-sl-u-ui
Today I was working on my project for school and we were using a power supply with 24V and we accidentally had the current at 0.9A. We heard a pop...
560
Hi all, I have been working on a project that requires me to measure the current across a 90 VDC motor of a medical device (similar to an...
26
1,579
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
683
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
351
VFD is not tripping at higher current , resulting in motor failure . VFD Model : Make - KEB Type - H6- 10H6BBBB-21B0
514
