leitmotif
DickDV said:Actually, I like kittydog's idea best. The problem with a DC drive is that the SCR's depend on the AC input to commutate properly. With DC inputs, that's not available and the concept becomes non-functional.
With a 220VDC supply, you could use a 230V three phase input drive, connect the DC directly to two of the inputs and get 230VAC out. Now, change out the DC motor for an equivalent hp and speed 230VAC motor and the problem is solved with all standard components.
Why not!
DICK I looked into taking an off shelf VFD (3 phase input) and hooking battery direct to DC bus for the electric vehicle project. Several people tell me that like what you stated with a DC drive the VFD uses the line 60HZ as the clock (time base or referance) for triggering the IGBTs. Are they correct?
Dan Bentler
