Dcs Plc Scada
Unregistered
Guest
U
I would like to know the diff in working principles of PLC, SCADA and DCS. The selection criteria for each of them.
Advance Thanx
multiple threads I see. Your book(s) glued shut?
I know guys this isnt my standard method of answering but geez these questions are so...........
SCADA is Supervisory Control and Data Acquisition, the name says it all. Its a program (usually run from a PC) that allows control and data acqusition.
PLC is just what the name implies...programmable controller. It was originally designed to replace relays, timers etc but as time has passed it has obtained capabilities far beyond the original concept.
DCS is Distributed Control System...in the other thread someone mentioned Logix5000 cards being used in a DCS system, well AB/Rockwell/Reliance has been doing that for many years. A DCS is a control method that distributes among many different processes.
There is a fine line today between all of the above.
Hi, I would like to know what are the PLC/DCS/SCADA brands that are widely used in CANADA. It would be great if there is some statistics. Thank...
1,819
If one primarily does PLC and HMI programming (say Rockwell / AB products, GE Proficy), how much of a challenge would it be to transition into DCS...
1,943
Hello i am seeking help on a University assignment. The Task Reads, Choose one of the topologies - Star - Tree - BUS - Ring - Mesh and show how...
19
4,110
i'm new to the field of automation.. can anyone kindly explain..what are the diffrences or similarities between these terms plc dcs scada hmi it...
5,125
