dde hot link, excell to slc500/4.
vernon1
Jan 2007
WEST MIDLANDS
60
Hi Guys , anybody out there got a step by step guide on how to set up a dde hot link between a pc and an slc 504,I have a comms path already using linx classic.
Just need to display some data table values in excell.
Thanks in advance.
If it is RSLinx lite, you can't. Unless there is a cheat way that I am unaware of. You need to buy RSLinx VS. the lite version that comes with RSLogix 500.
Marc
Step by step
1. Set up DDE/OPC topic
a.Open rslinx pro (not light)
b.Select menu item DDE/OPC > Topic Configuration
c.Select path, processor, topic name,...
2. Copy the link
b.Select menu item Edit > Copy DDE/OPC link
c.Select server, topic, data address,block size, ....
d.click OK
3. Paste the link
a.Open Excel (or other target app)
b.Select the target cell
c.Select menu item Edit > Paste Special
d.Select Paste Link > OK
You can pick up the syntax from the link for doing others more quickly.
Vernon,
Cheapest option (via AB anyway) is the RSLinx 'Single Node' license (about £285 list las time i checked). You can then create direct links between RSLinx and (for example) Excel (called 'Topics').
You then basically use 'paste special' in the pc application to create a path to the PLC data file...
Once you've done it once it's a breeze (in my opinion!) - then you can create all sorts of fancy stuff in excel to view the dynamic data (y)
Hope this helps!
Rob
vernon1 said:
cheers guys for all of your feedback.
I think I have an RS linx training giude that gives step by step instructions screen shots etc. on how to do this, and a lot extra. I will post it tomorrow when I am at work.
Myles
This thing is 1.3M and to large to post, Xp will only let me send it to a compressed folder new size 1.1M. Anybody got any ideas? someone with winzip and an email address that can post it?
myles
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
94
Hey Friends. I am currently trying to write approximately 700 tags from FtView13 to an Logix Emulate 5000. I am using rslinx DDE/OPC to create an...
402
I am upgrading an old RSView32 v7.60 HMI to FactoryTalk View SE version 12.0 and I have an issue. There are some excel reports generated daily...
1,017
This used to be an easy task in the past to get data into Excel, now I have 365, Excel just hangs when I paste the link. I've seen some guides to...
1,252
Hi, I'm brand new to the forum and spent some time looking around but could not find an answer to my question. I'm using an excel spreadsheet to...
1,343
