DELTAV -fract function
Olga
Aug 2018
Glasgow
Hi!
I'm currently doing a project on DeltaV, and the fract function in my code does funny things.
I have a measurement in MWH which can be eithe a whole number or have 3 decimal places. For example the value of 299.645 MWH is displayed as 299 MWH and 645 KWH. I used trunc and fract functions to separate these into MWH and KWH.
The issue is, when I write a number which decimal place ends with 1-5, the value displayed in the KWH section becomes off by one and the same happens sometimes when I use a random combination of numbers.
For example when I chose the value to be 299.3 MWH it displayed 299 MWH and 299 KWH or when the value was 856.358 MWH it was displayed as 856 MWH and 357 KWH.
The code works correctly most of the time, but some times it gives me a value of KWH which is off by one. Can someone please help me fix this issue?🤞🏻
Many thanks,
Olga
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
112
Hello, Does anyone know how to export the EDD files for a device in DeltaV Explorer 12.3? I can export the .fhx, but I have no idea how to get...
134
Hi experts hope you are well. Would any one be able to tell if it is possible to pull data from a Delta V DCS and display it on a TP700 comfort...
458
I have a DeltaV system that I am using to control some powerflex 755 drives over Ethernet/IP. I don't have any experience with DeltaV or any way...
792
One of my customers wants their DeltaV system to communicate with my Compactlogix PLC. Is there any specific hardware (module?) I need on my end?I...
1,207
