DeltaV - Ifix problem
Apr 2003
Belgium
434
Hey overthere,
I desinged a Picture in Ifix which is part of DeltaV. Now when I open my window in DeltaV operate (run) I get the message "The picture you just loaded into the main window is not a main window picture".
How can I convert this picture into a main window picture?
Rudi
Fritz_frederix said:
...How can I convert this picture into a main window picture?
Rudi,
Not sure how you "generated the blank slate and then started making a picture" but my method is to open either main.grf or Main1280.grf form the /Template/ subdirectory under /Pics and then save it to the /Pics directory under a different name. e.g.'Master.grf', once I have set up the desire baseline background and any control formating that I will use on similar screens. Just keep reopening the master and then Save As for the various new displays.
To save what you have already done, open up the Template grf, Select All then delete everything. Next Select all on the "bad" grf and copy them to the template file. This usually gets rid of whatever was bugging the system that the basic file format/ type/ info wasn't set exactly as Ifix was looking for.
Mike,
Thx that part works, Now I have just one more question if you don't mind.
How can I put that picture right in the opening of the Operate runtime. It seems always to schift. I modified the Window properties Document height and document with. But it doesn't same to help. What alse can I do.
Rudi
Ifix/ Operate is fussy on what standard template you use to set up your graphics. You using a standard 1280 x 1024 screen res? If so, use Main1280 as the template. I, too, have had this problem in the past and basically just started using the 1280 template. Their is some trick to get it to work with other settings, you can try to decipher the Usersetting.grf as it's probably buried in there somewhere. Just be sure to have a backup copy of it first in case you get hosed with the changes. UserSetting must be stored in the /Standard subdirectory and not stored in just the /Pics directory.
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
114
Hello, Does anyone know how to export the EDD files for a device in DeltaV Explorer 12.3? I can export the .fhx, but I have no idea how to get...
134
Hi experts hope you are well. Would any one be able to tell if it is possible to pull data from a Delta V DCS and display it on a TP700 comfort...
459
I have a DeltaV system that I am using to control some powerflex 755 drives over Ethernet/IP. I don't have any experience with DeltaV or any way...
792
One of my customers wants their DeltaV system to communicate with my Compactlogix PLC. Is there any specific hardware (module?) I need on my end?I...
1,208
