DeviceNet 1734-ADN on SLC
michev
Nov 2014
VA
I am in the process of adding a new node to an existing DeviceNet network with a SLC 5/05 PLC processor. The scanner on the main network is a 1747-SDN and I am adding a 1734-ADN. I have created the subnet for the 1734-ADN, but I'm having doubts as to whether I have enough memory mapped and where the IO will be mapped to in the processor. The network is pretty full, so I'm hoping what I think I have learned the last 2 days cramming has come together correctly
The 1734-ADN subnet will have 1 8-point input (1734-IB8) and 1 8-point output (1734-OB8E). I have mapped 2 bytes(?) for input and 2 for output. I'm not sure if I need to map the status bits as well (not being used by my PLC program). From the attached files, can anyone confirm the IO data will be mapped to M1:1.148 (input) and M0:1.148 (output)? The adaptor/scanner is assigned node 55 on the main network. Ultimately I would like for input 0(through 7) on the new IO to go to M1:1.148/0(through 7) and output 0(through 7) to go to M0:1.148/0(through 7).
Thanks for any help!!!
I'm trying to upload the Subnet file from a 1734-ADN DeviceNet module. I'm drugging down in RSNetworks to the Subnet port but when I click ok it...
2,589
I have a DeviceNet network on a ControlLogix PLC consisting of a 1756-DNB and about 30 nodes of VFD’s and 1734 I/O’s. The problem I’m having is...
2,785
Hi, I'm having issues commissioning a new PointI/O module (1734-4IOL) on an existing DeviceNet network (1756-DNB). I am adding the 4IOL module to...
831
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
111
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
149
