DeviceNet Block (Compact)
abwiz
Nov 2005
PA
196
Does anyone know of a compact (high density) DeviceNet box that I can use on the end of a robot arm? I would mount the box on the End Of Arm Tooling and wire all sensors to here. Then I will just have the communication cable to worry about for cable managment. I would need like 12-16 I/O. Any thoughts would be great.
Thanks for the response. I have used those before. They don't exactly comply with the compact and high density requirement. I need something alot smaller to carry on the end of a robot. This what I am having a hard time finding.
The Allen-Bradley CompactBlock and CompactBlock LDX are about as small as I've seen. Any smaller and you're going into some really small sensor wire connectors.
Small and compact use AB Compact blocks like Ken said. I am doing another startup tomorrow on 2 ABB with wireless end effector I/O. I went with Pheonix Contact. The only wire management we has to do was 24 vdc for power. 1 (2) pair cable for power. 2 hots 2 0VDC this covers me for a single wire break. If you have base I/O existing this is a nice add-in
Hi there, I am establishing my deviceNet and using a CompactBlock I/O (1791D-16B0) as a node which works properly as input. I have an expansion...
1,000
Hi all I have here an AB PLC system including: - 1768-L43 CompactLogix PLC processor, firmware upgraded to 20,12 - 1768-ENBT Ethernet scanner...
4,367
I have a Cat # 1792D-16BVTOD ArmorBlock Maxum 16 input module for Device net. There are already several magnetic reed switches connected to this...
3,621
Can someone please clue me in on how to set up a CompactBlock module with expansion on Devicenet? I have a 1791D-16B0 input module with a...
3,133
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
34
