DeviceNet DaisyChain
Jmeadows7676
Oct 2013
Alabama
158
Hello,
I was wondering if anyone knows if it will be ok to have a DeviceNet Daisy Chain with the Nodes not in order.
Example: Scanner Node 0 going to node 7 then to node 6 then to node 5.
Does anyone see a problem with this.
Thanks,
Hello,
Thanks,
I've never had any issues with nodes out of order. Once they are all found it should be good.
It's physically a parallel signal bus, so every device sees every transmission at the same time on the wire.
As pattern-recognizing humans we love to see things in sequence, but it does not matter at all to the DeviceNet network devices.
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
113
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
150
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
133
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
210
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
111
