DF1 Comm to Compactlogix
davidgay
Jun 2002
29
Hello Everybody. I am trying to read/write to my Compactlogix using DF1 protocol across the serial port to send/get an array of 6 integer values. I have a VB6 program that does this to Micrologix that works just fine. I connect up to the serial (CH0) port on the Compactlogix and I get NAKed from my message. I have mapped an array of 7 integer values to file 7 in the Compactlogix. This is wild new territory for me talking to Compactlogix so any help will be greatly appreciated.
Is there something special I have to do to set the serial port up? or do I have to change the addressing in the DF1 command or something...
the reason for all this is we have a home grown VB6 HMI program that is setting/displaying data on the PLC. This works fine talking to ML1000s but the ML1000 doesnt have the I/Os I need to make it work on the machine I'm retrofitting.
Also, I have read the DF1 protocol manual, as well as the Logix 5000 Data Access, and others... just can't find the "missing piece" I need to get this to work.
Again any inputs will be appreciated...
David
Heh. Good point, Jay.
Probably it's an error checking difference. MicroLogix controllers use only CRC error checking, while ControlLogix (inexplicably) defaults to the simpler BCC error checking type.
The CompactLogix can be easily configured for CRC error checking in the serial port configuration tab of the Controller Properties dialog in RSLogix 5000.
Ken,
Thanks for the info... I wasn't aware of the difference in the error checking. I appreciate the input and will check on it and let everybody know the results.
I want to thank all of the people who have taken the time to examine this thread, it never seems to be the big stuff that trips me up always the little details... but that's what makes our jobs soooo interesting, huh?
Thanks Again All!
Hi All, I have run into something strange and some of you great minds out there can help me out. I'm trying to connect to SLC 5/05 controller...
3,782
Setting up a PanelView-550 to communicate with Compact Logix, using a laptop to set it up. DF1 using USB<> RS232 converter using a BELKIN...
2,588
Can anyone explain how to setup communication with an SLC5/04 using DF1 half duplex, or at least if resetting the processor defaults CH0 to DF1...
12,214
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
118
Hi, I appreciate any help to make connection between AB DF1 Micrologix 1200 and WinCC Adv project (PC station - not HMI) possible. For now I can...
610
