DF1/RS232 Port Splitter
bgrove
Nov 2017
Michigan
Anyone have any experience with using a 1747-DPS2 device? Bascially, have a Micrologix 1000 where the round port is being used by the HMI (Panel View 300). Scenario is that we need to get this Micrologix on the network to an OPC Server for data collection. The idea is to come out of the controller to this 1747-DPS2 device. Then plug the HMI into the device and plug our DF1/RS232 to Ethernet Gateway into the other serial port. I realize this product is discontinued, and I've seen a few forums where some had issues with the device timing out. Unless there is another device out there that I'm unfamiliar with that can split the DF1 into two serial connections.
Just remember that when you're splitting the DF1 port that you are splitting DF1 half duplex. Some of the DF1 bridging devices (like the NET-ENI) only work with DF1 Full Duplex which can't be split.
I am having trouble with communication between my micrologix 1000 and my magelis HMIGTO5310 touchscreen i have added the allen bradley df1 driver...
1,483
Has anyone tried DF1 with the RS232 to TCP servers? RS232 to TCP WIFI servers? Curious if anyone has had any luck. I'm thinking of trying it with...
2,302
Hi, I am trying to download a program onto the a PV550. The program was initially written for a PV300 with DF1 communications. The PV550 has...
2,318
Hi all. I am having trouble getting a Siemens OP277 and an AB SLC504 to talk to each other via DF1. The older panels OP25/OP27/OP270 had an...
2,092
Does anyone have experience with changing the channel 0 mode to user remotely using RS232 communications? I have checked the mode change enable...
4,218
