DH+ overview
xC0MMAND0x
Jul 2013
Minnesota
265
My understanding / short explanation is that DH+ is a communications protocol between different devices, that uses channels, nodes and link IDs.
Can anyone point me to some reference material or give a more in depth explanation of DH+? From the beginner level. What types of cabling is required/used? What kinds of devices? What kind of speed ratings? Maximum devices, configurations.
School me.
Throw any info you have at me - I'd appreciate it.
Thank you!
You're on the right track.
Data Highway Plus was the most successful of the Allen-Bradley proprietary networks in the late 1980's. It is used to connect controllers, HMIs, and programming terminals and uses a token-passing peer-to-peer protocol.
Node addresses are expressed in octal; the sixty-four possible node addresses are 00 through 77.
It's a transformer-coupled two-wire system; don't let anyone tell you it's RS-422 !
The data rate is 57,600 bits per second for older devices. Newer ones (and by 'newer' I mean 1988 or so) can run at 230,400 bits/second.
Cables can be quite long; 10,000 feet total at 57.6 kb/s, and 2,500 at 230.4 kb/s.
The Belden 9463 cable has a characteristic blue jacket that led to the common nickname "blue hose" for DH+ networks.
The Allen-Bradley Universal Remote I/O network (RIO) uses identical hardware and cables but fulfills a different function; it's purely a master-slave I/O network. It cannot co-exist on the same wire as DH+ protocol.
Go to the RA Literature Website and just use "Data Highway Plus" as the search keyword.
You'll find classics like the DH+ Product Data brochure, and the Data Highway family networks cable Installation Instructions.
Hi Friends! After designing a scada screen WITH Wonderware indusoft, how can I incorporate it to a website so that operators can login from...
2,288
Hi, When you have Simatic Manager + WinCC Flex integrated and Drive ES. Then you connect HMI's and DRIVES. When you don't configure DP keys in...
2,343
Hi, Can someone give me a glimpse of different PLCs and DCS available in Honeywell. Ex: In Siemens we have PLCs classified as 200, 1200, 300 ,400...
9,821
Hello everybody, does anybody brochure CC-Link Specification - Overview/Protocol BAP-05026-J ? It's in CLPA organization but i have problem with...
1,716
I've had a look around but haven't found a quick setup guide or anything akin to that. I'm after what sequence things need to happen, and what...
14,662
