Simatic Manager: Connections overview doesn't show drives
userxyz
May 2002
any
2,768
When you have Simatic Manager + WinCC Flex integrated and Drive ES.
Then you connect HMI's and DRIVES. When you don't configure DP keys in the Hardware Config, then in the Hardware Config, you will not see the panels. I do understand this, because for the PLC it isn't important information when no DP-keys. The normal Panel aquisition time is used then.
But, in Connections I see The PLC rack, The HMI's, but... the drives configured in the Hardware Config cannot be seen ? How come ?
And last but not least, will this be solved in Portal 11 ?
Regards,
Combo
Do your other slaves show under Netpro?
Is this what your referring to?
In netpro under View> slaves- is this checked?
This may sound stupid, but I didn't know that I had to set the slaves on myself in Netpro :). Now that I'm writing a summary on a project, I wanted a proper overview of the topology, and I bumped into this.
Thanks,
Regards,
Combo
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
321
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
275
Hello all. I went to a customers location, uploaded from the S7-300 (CPU312) and performed a save, performed some work then came back to the shop...
613
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
760
Hi, I have recently gone full in on TIA after holding on to Simatic Manager. One thing which I find more difficult is the filter function for...
1,729
