Dh485 Drivers Configure Slc503
traveltyme
Jul 2008
illinois
39
I'm new to this and need some help. I cannot communicate with my SLC503 DH485 link. Configured RSLogix driver for DH485 (EMU) only choice, Config'd processor for dh485, When I do a WHO, RSLogix driver box displays "processor is not an SLC 500------ HELP! DOES COM using serial DF_1 config.
Cheers,
Ray
magicsmoke said:
are you plugging your cat. 5 into a 1747-uic module or are you just plugging it into your ethernet port of you laptop?
I hope NOT!!!
The SLC5/03 does have an ethernet port its a DH485 port. Do not plug it in to your PC's ethernet port. ( if thats what you were going to do.) You will damage your PC/Laptop.
To use the DH485 port you need a 1747-PIC or a 1747-UIC ( USB to DH485 converter)
See PDF's below
Well thats just DUCKY! Yes, fom PLC dir. to ethernet port on PC. Should have known better with this Rockwell stuff Ya have to have some kind of $5000.00 convertor, silly me!
Check your PC's ethernet port you may have damaged it.
Your best bet is the UIC. Price not all that bad
ON 504 DH+ Could I go straight between PLC and PC? and what would the processor config. be? ie: Channel config. CH0 USER CH-1 SYS. on line HELP does not explan SEtups. AND yes(i'ts been a while) I totaly forgot,mea culpa, 501's use this! Been years since i touched this stuff
Ray
Mickey said:
I hope NOT!!!
See PDF's below
Correction to the above statment: (typo insert not)
The SLC5/03 does NOT have a ethernet port.
Yea Mickey
It's all coming back to me now--- I was going to say, I thought ethernet is 05' and that PIC was for PARALLEL ports------ON 504 DH+ Could I go straight between PLC and PC? and what would the processor config. be? ie: Channel config: CH0-1 USER - CH-1 SYS. on line HELP does not explan SEtups. Can you explain?
Read the document you posted, spot on! Anything re: DH+ qeustion? And FINALLY------ For some reason, My Linx Workstation Icons changed from a PC and proceeor, to (2) Globes?
What's with this?
Thanks MICKEY, You RULE!
Ray
See my post number 9. You can go straight from PC to SLC5/04's Channel 0
serial port. You will need a null modem cable. Leave Channel 0 set for system mode.
You cannot go straight to the DH+ port from you PC. (see post 9)
See pic's below for the SLC5/04 default settings. Be advised channel 0 can be configured for DH485. Do you have the offline file to check its setting?
Hello all, i have seen a few things here and there about connecting to a panelview 550, however i still would like to ask a few things, I have...
141
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
906
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
685
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,333
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,364
