DH485 Network
02js4130
Jun 2014
Wales
38
i am trying to create an DH485 netwrok which will consist of 2 ML1500 using ACi units for data acquisition back to a pc. i understand how the PLCS join using the AIC , My question is how is the cabling done to connect to the PC and what protocol is used? also how are the node addresses applied?
Thanks in advance
ok thank you, so from the final node i use RS232 cable and DF1 protocol back to the pc?
The protocol of your ML1500's are set to DH485 you will need to use a DH485 driver (1747-PIC/AIC Driver) in RSLinx. The AIC's are not a protocol converter, just a interface converter.
Does your PC have a real serial port (9 pin port) if not then the 1747-PIC/AIC driver will not work. You will need a 1747-UIC (USB to serial converter)
it is a interface and protocol converter. You can then use the DF1 driver.
See pdf
I have an allen Bradley system in which there is two micrologix 1200 and two panel view 300 and a Rsview 32 connected on DH485 network with the...
1,775
Hello All, I am currently troubleshooting a communications issue regarding a DH485 network. The network contains PLC1, PLC2, and PLC3, all AB...
3,802
So I am attending a site next week that is reporting PLC communication issues between its three SLC 5/03s (PLC1, PLC2, PLC3). PLC2 communicates...
1,802
Hi, I want to know if and how i can bring up my DH485 network to a ethernet/ip. My network is setting with 1747-aic and 1761-net-aic. So i...
2,299
Hello all, I have an Allen Bradley DH485 network that currently has three devices. Micrologix 1500 LSP series C w/1764-24awa base node 1d...
4,618
