DH485 Network not communicating.
Nole
Jan 2016
New Brunswick
So I am attending a site next week that is reporting PLC communication issues between its three SLC 5/03s (PLC1, PLC2, PLC3). PLC2 communicates with PLC1, and PLC3 via a DH485 network, and then sends all the required PLC data to an RTU via Modbus. PLC2 is communicating properly with the RTU, but only the values for PLC2 (not PLC1 or PLC3) are updating. Apparently this issue has existed for years, and other engineers have tried to fix it with no luck.
This leads me to believe that there is an issue with the DH485 network. I attended site yesterday, but could not connect to any of the PLCs as Chan. 0 (RS232 port) was configured as shutdown in the program, and I didn't bring my DH485 programming cable. (rookie move šŸ™ƒ)
My question is, what is the best way to get online and troubleshoot the DH485 Network? My current plan is to go online with PLC2 through the DH485 port, take an upload of the program, reconfigure the program's Channel Configuration to allow Chan. 0 to communicate DF1 Full Duplex, then download the program back in. After this is complete, I should be able to connect to PLC2 while the DH485 cable is plugged in to allow me to troubleshoot the network, right?
Two other points:
- There will be an operator on site who can put everything in manual while the download takes place.
- The SCADA PC on site has been down for 7 years according to operations.
If anyone has any better ideas of how to troubleshoot this issue, it would be greatly appreciated.
Sorry if this isn't a great question, I usually deal more with electrical issues, and Ethernet communications and am just learning about Allen Bradley Comms.
Thanks,
Why would someone do that to chan 0??? thats just Rude. lol.
thats crazy that this has went on for years withought resolution.
No doubt. I've never seen it but I've heard of guys on new installs setting up "random" faults in the logic after warranty so they call you and you make money and that is just greasy. works good till they find someone else and he finds that.... they should get sued
I have an allen Bradley system in which there is two micrologix 1200 and two panel view 300 and a Rsview 32 connected on DH485 network with the...
1,775
Hi, i am trying to create an DH485 netwrok which will consist of 2 ML1500 using ACi units for data acquisition back to a pc. i understand how...
2,008
Hello All, I am currently troubleshooting a communications issue regarding a DH485 network. The network contains PLC1, PLC2, and PLC3, all AB...
3,802
Hi, I want to know if and how i can bring up my DH485 network to a ethernet/ip. My network is setting with 1747-aic and 1761-net-aic. So i...
2,299
Hello all, I have an Allen Bradley DH485 network that currently has three devices. Micrologix 1500 LSP series C w/1764-24awa base node 1d...
4,616
