Din Mount PC
cmgrath7093
Aug 2016
Ohio
I am currently looking for a DIN Mounted PC with windows 7 or xp so with Ethernet IP and HDMI output to install in a control panel and run Factory Talk View ME on and display on a HDTV. Any suggestions as to the best place to get one?
We have just used a B&R IPC. B&R does not currently have a HDMI port, so we needed to use a DVI-HDMI converter.
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
136
I've got a new and different project and I need a DIN mount UPS with 120V output. SOLA comes to mind but are there any other options you folks...
1,139
I have to mount a lot of slotted din rail and just ordered today. What is the best type and size of screw to use? Course or fine thread? I am...
20
2,482
Just wanted to check and see if anyone can suggest an image storage method for vision systems. I have done some of this before with FTP to a...
4,234
I am trying to find a shallow (<85mm depth) network switch. Trying to keep width under 70mm. Height is flexible. Unmanaged or managed is okay for...
4,030
