DIN rail mounted momentary push button?
danw
Oct 2004
midwest, USA
3,428
Anyone know where to buy a DIN rail adapter for a momentary pushbutton, or a momentary pushbutton ready-made for DIN rail mounting?
It's to be used for a test; mounted inside the panel to avoid passersby playing with it.
Can I get a pre-engraved label that says "Do Not Press This Button" ?
In my neck of the woods you would have better luck if you put a label that said "please press this button". "Do not touch" would be too irresistible.
If I didn't want anyone touching it I would padlock the panel.
Dave
Dan if you find anything from AB let me know. I have a customer that is die hard AB meatball guy. If it doesn't have a meatball you can't use it. I have been using AB 22mm single button enclosures mounted in a panel. Not very pretty, but it works
I have one guy that will NOT accept anything that isn't AB.
I ordered a 100 breaker from my AB rep and it came in as a Cutler Hammer. No big deal I thought he had a cow.
hi all, we have several weimuller din-rail mounted outlet in the plant. I need to install 5 more, but I'm not able to fin it on the weimuller...
4,108
Hi all, Just a quick question, Has anyone ever worked with a DIN Rail adjustable RC filter or an instrumentation amplifier with a built in...
5,026
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
141
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
590
