DIN rail mounted momentary push button?
Dan if you find anything from AB let me know. I have a customer that is die hard AB meatball guy. If it doesn't have a meatball you can't use it. I have been using AB 22mm single button enclosures mounted in a panel. Not very pretty, but it works
I have used the 800F-BX.. base mount contact blocks that mount directly to the back pan (not DIN rail though) and then mount an operator on a simple C bracket above it. Can't use it for pulling style operators, but I've done it with the selectors, PBs and toggle operators, usually as a reset inside of the panel. Last one I did, I used a short piece of Panduit as the way to hold the operator, just screwed the base mount contact block right through the panduit base.
http://epub1.rockwellautomation.com/images/web-proof-small/GL/1571330.jpg
Nice layout. What software do you use to make your layout drawings?
Thanks!
I use AutoCAD and I draw most everything I build in 3D. I learned 2D AutoCAD years ago, and 3D was a natural extension. I'm planning on learning full blown parametric modeling next. I really want to start using SolidWorks.
-rpoet
hi all, we have several weimuller din-rail mounted outlet in the plant. I need to install 5 more, but I'm not able to fin it on the weimuller...
4,111
Hi all, Just a quick question, Has anyone ever worked with a DIN Rail adjustable RC filter or an instrumentation amplifier with a built in...
5,026
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
141
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
590
