Direct Automation Pointers
plc noob
Oct 2007
atlanta , georgia
258
guys
i am trying to use pointers in direct automation . i ahve looked at the example in the 06 hardware manual and downloaded some examples . i do not understand any of it . can someone break this down a little better ?
The Dl-06 "Pointers" is a method to achieve indirect addressing. In other words, the instruction does not operate on the address but on the value in a second address that the current address "points" (refers) to. By using pointers, you can do loop routines, where you keep doing the same operation, but on a different set of numbers each iteration, by simply changing the Pointer address.
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
141
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
147
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
585
Anyone tried Automation Directs new CM5 HMI. We've been the EA9's for a few years now with minimal complaints. A few failures here and there but...
17
1,616
I'm using an Automation Direct GS20 VFD for the first time and I have a question for the Automation Direct gurus regarding the recommendation of a...
1,110
