Disable printer port on AB PanelView 600
andreakog
Jun 2007
italy
Hi to everyone,
I'm writing from Italy...
I'm trying to disable the rs232 printer port of an AllenBradley Panelview 600 but I can't reach my goal:
1- I enter in configuration mode pressing <> buttons on terminal
2- I enter in printer setup
3- I press F7 function key to toggle "enable/disable" printing
but... when I press the F7 key it doesn't toggle at all!! The Key is functioning (the button on the screen become hilightened) but no action occour... :(
so printing is always enabled and I can't upload/download the application.
Do u know if there is some other method to change?
Thanx in advance,
Andrea.
rPraveenkum said:
what is the cat. no of the PV
I hope in certain PV the Printer port can not be diable it is dedicated printer port
it's a 2711-K6C9... on the manual is specified that you can change the mode... maybe it has a old firmware revision?
rPraveenkum said:
2711-K6C9 has only printer port you should use the other port(Port:rs232 protocol :dh485) for upload/download.
I've tryed also the other port but no success...
I've used this cable pinout:
2-2
3-3
4-4
5-5
6-6
7-7
8-8
on the panelview there is a running application, I need to backup the application.. the port speaks with a SL500 and when I try to communicate with rslinx DF1 the autosensing doesn't find the right config... also trying directly from panelbuilder32 has no success :(
I need to commuicate through 485 with the pcmcia PCMK adaptor?
i went to the configuration mode in panel view 550 and went to printer set up page. i found the port was enabled. i tried to disable it by...
5,326
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
173
How can we disable the DHCP server on a Stratix 5700 ethernet switch? It is running on a machine with Rockwell automation and drives. We...
1,589
Hello. We have a Powerflex 700s phase II firmware 4.002, but the encoder card is burned. We want to disable it to use the Drive without motion...
459
As above. I've been fishing around on TIA portal but haven't found a "Disable channel" tickbox. Is there one? If so, where is it? Cheers
1,339
