Distributed I/O
octoleeber
Nov 2010
Florida
Im installing a Yaskawa MP2300Siec motion controller and I will also need some distributed I/O on my machine(Digital,Analog,Temperature control).Any suggestions on modular products that work well with Yaskawa?
Yes. You will need to install DeviceNet module 260IF and use any available DeviceNet I/O. I personally have had good experience with Beckhoff, but Wago, Allen-Bradley, Omron or any other should work as well. Be aware though that your I/O will lag the local I/O at least 10 ms or so. If you do need faster responses (as fast as the CPU H-scan), you would have to use one of MP2000 I/O cards.
There is also Ethernet/IP module available (263IF) and it does work with Beckhoff and Wago. However, the bus speed is no faster than DeviceNet yet the module price is much higher than 260IF.
The day when Yaskawa finally comes up with EtherCAT master module will be one of my happiest. Not there yet, unfortunately.
PS After I posted my message, I realized you are talking 2300iec, not 2300. This is a different animal, with different firmware. I think, Ethernet/IP maybe the only option for it, but not 100% sure...
Alarm Server Connection Status I am trying to tie a color animation to a rectangle that changes color when connected or disconnected from the...
526
Hello, I am trying to make a copy of a FactoryTalk SE Network Distributed application. I want to make modification but do not want to work on...
1,168
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
962
I have a customer asking me to do some testing on non Rockwell I/O. They want to see if it will work. Thats simple hookup a PLC, put the IO in the...
1,135
Hello to Everyone! I am looking for Ethernet/IP Distributed In-Cabinet IO Block options to talk to Compact Logix PLC (L36ER). I only need 3 DO's...
3,012
