DL330 psuedo one shot pulse
Caledonian
May 2009
Tasmania
Hi all,
I'm currently porting a program from a DL330 based PLC to a micrologix 1200. It looks like the original programmer has coded a sort of one shot pulse:
| Momentry_PB PB_log_coil 1_shot |
| Momentry_PB PB_Log_Coil
*edit*: well my text based representation didn't come out so well but you get the idea...
So as the cpu scans through the rungs the first rung is energised. As soon as the second rung is scanned it switches off the output of the first rung, so the output stays on for no longer than a single scan of the ladder.
Now, as there is a one shot pulse function available in the DL330 instruction set, can anyone think why it would be coded this way? Is it just a programmer a bit set in his/her ways and unwilling to try out these new fangled functions or is there something a bit more sinister happening.
I only have a 24 hour period to get the new plc installed and working so I want to make sure the program is right before I go for it.
Cheers!
The first Series One CPU, which the DL330 is a successor to, did not have a one shot in its instruction set. That function didn't appear until the Series One Plus. Your program could be a legacy from those days.
Your understanding of the operation is correct. There is no reason not to use the MicroLogix one shot instruction.
Hi, I need a diagram to build the Cable GE Fanuc/Koyo DL330 to PC. I want to backup two olds DL300 that i own. Thanks in advance Please help!
4,253
Hello all. This is a very lonnnnnnng shot but worth a try. I have an OMS Group Impact100 metering machine. At this customer it blows foam into 3d...
187
Howdy Everyone, So I have been retrofitting a cell to run different fixtures and updating it with new drives and a few other things. It runs...
1,505
Hi all, I am working on a ladder program in AS and I was to trigger a reading on my IO link sensor every .5 s, and use that value to run a...
542
Hello Everybody, Someone must be familiar with Horner Cscape, I wrote a program on a overhead door with a 3 button station,I'm working on a...
1,458
