I'm almost there. I can follow you up to "point it to the PLC via the driver you require" Do I just select (highlight) the node under the appropriate Ethernet driver, then click on the Download button at the right?
If that is the case, then clicking "Online" would let me do editing, RUN, etc. Is that the case?
The problem is that I'm not on that network at the moment (or I'd just try it) but I need to be prepared. I'm somewhere in Houston, far from home, with the clock ticking and greatly appreciate your help.
