Downloading to Siemens Coros OP15C
Kristoffer
Jan 2006
Melsomvik
My client has a OP panel (OP15C) on a machine we have done some mechanical upgrade on. Unfortunately I managed to disconnect the backup battery, and I need to put the program back into the OP.
Luckily I have the source file (a *.O15 file). My question is:
Can I use ProTool/Pro CS to download the program, or can I use ProSave, or do I have to find some way to use that old ComText program?
I have the ProTool v6.0 SP3.
Thanks...
Hi Kristoffer.
".O15" sounds like it is a COMTEXT program.
There is a konverter to Protool "KONVERT", but I think that it does not convert everything 100%. I have not used it.
I wouldnt be surprised if it doesnt work in XP. Up to NT is mentioned in the supported OS'es. You can try to start an MSDOS prompt in compatibility mode.
Also, it only converts the texts, not tags or screens or keys.
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,200
Good Morning , I'm new to the Siemens LOGO software. Have any of you had a problem downloading this Software from the Siemens website ? I...
1,182
Hello all, Newbie in Siemens, I want to ask if there will be any issue when I download the instance datablock of a certain Function block? Also...
4,423
Hi, For some reason when I try and download a pdf file from the 'file browser' in the Simatic HMI Miniweb, Chrome and Internet Explorer change the...
2,242
[Just realized my 100th post! wohooo] Hey everyone it has been a while, I have a few questions regarding download for the siemens experts more...
2,211
