E-terminal Networking problem
Jan 2007
Florida
I have an E-1061 terminal from Mitsubishi. I can use it to talk to a PC and even my PLC, but not through a hub. Anyone ever encounter this before? Any recommendations?
I can use the same hub to pass info from PC to PLC, so I know the hub is good.
double check the ethernet cable
a crossover cable is used between two computers, but a straight through cable is between a computer a hub.
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
120
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
235
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
163
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
964
Hi all, i have a panelview plus terminal 2711P-T12W22D9P terminal with different user names and passwords. Everyone seems to know the maintenance...
807
