E1101 (E-Designer) digital fill function
Blijj
Jul 2008
Carmarthenshire
36
Hi all. Does anyone know if I can use the digital fill function in E-Designer 7 to fill an area bounded by freehand drawn lines or has it got to be, say, a rectangle from the "draw rectangle" menu?
Thanks.
Blijj
Yes you can, it works fine, I just checked.
you can check it yourself, make an input button and give it an address, set the fill in the middle of the area and then address the fill the same as the button.
run the project on the PC (F5 if I remember) and click the button you made, this should change the fill colour or whatever you want it to do.
Chris
Thank you Powerplan. I didn't have a screen to test it on and the last time (last week) I started the simulator the application crashed while exporting and wiped my v badly backed-up prog šŸ™ƒ Kept me busy this weekend. All back (and backed-up) now. Mits guys are looking into it...
we have a Mitsubishi E1101 on site that if turned off for an extended period of time boots up with no program. I assumed the internal battery was...
1,289
Hi Guys, I have the task of setting up communication between a S7-1214C with Version 3.0 Firmware, and a Beijer E1101 HMI. This needs to be done...
4,648
Hi Everyone, Im trying to connect a Mitsubishi e1101 HMI to a modicon quantum controller. I am really struggling to get it communicating with the...
1,616
Hey, I have a small problem that I hope someone here could help me with. I'm trying to set up a transparent mode so I can monitor my program...
1,872
I am trying to set up a remote desktop connection to a E1101 HMI from a Laptop. I have set the remote access check box in network services...
3,079
