Easy Builder Pro
roxusa
Nov 2008
NJ
994
I converted a Maple Systems EB5000 Project from a discontinued screen into a EB8000 Program and from there to a EB-Pro I have a MT8012iE screen and my problem is the MT8012iE has a resolution of 1024 x 600 I am told and it is not listed in the Model types selectable in EB Pro
I have tried several of the types available but cant get the objects to fit right on the screen. I either end up with a 7" window on a 10" screen or a 12" window on a 10"
I am new to EB PRO but have been using the EB8000 for a while
While using EB8000 I know they don't show the MT8070iH I have been using but I can pick one with the same resolution and it will work.
Anyone work withe the MT8102iE with EB PRO........THANKS
I got it I had to upgrade to v.5.6 I was running v.4
Hope this helps someone else someday
Hey All. Im using Easybuilder pro. Im familiar with using the enable/disable function of the security tab on an object to use visibility. Im...
2,084
Hy guys ! I've been making some projects in this easybuilder pro for weintek HMI, and i am struggling with a tiny problem but i can't seem to...
2,830
Hello all Kindly I need to know how to make online simulation between easybuilder 8000 (weintek) and s7-200 plc Which cable type is required...
1,748
I am using EB8000 building displays for machine temperature readouts and all is working fine. I recently incorporated one into a process machine...
1,657
Hello Friends; I use FX1N-14MR PLC with 6070i 7 inch display HM. I design the screens and create tags by using tag editor. But PLC not response...
2,858
