Easy Builder 8000 V 4.65 Tag Editor
jcp
Feb 2010
Multan
369
Hello Friends;
I use FX1N-14MR PLC with 6070i 7 inch display HM. I design the screens and create tags by using tag editor. But PLC not response when i use user difined tags.
If i give the direct addressing then it work well.
With the Tag editor the address shown as
ACK_PUSH
M-30
while direct shown as
M
30
If any expert use the tag database please guide me how the TAgs editor work in EB 8000?
Regards
I'm not an expert on this stuff,but like to try,
after read the manual user,
it's out like this refer to attachment,
maybe other members have better idea then me.
I've never used the tag editor, so I don't know if it works or not. I create tags when I create the button.
Don't use Set On, Toggle, etc. Only use momentary, and do latching in the PLC.
Hello;
I have no cable to communicate with laptop to the fx1N-14MR.
Is it possible to manufacture by self ? I need pin configuration to write and read the Ladder from and to PLC FX1N-14mr with Laptop 9 pin Serial port.
Please send me pin assignment on both ends.
Regards
Hello all Kindly I need to know how to make online simulation between easybuilder 8000 (weintek) and s7-200 plc Which cable type is required...
1,745
I am using EB8000 building displays for machine temperature readouts and all is working fine. I recently incorporated one into a process machine...
1,657
Hey All. Im using Easybuilder pro. Im familiar with using the enable/disable function of the security tab on an object to use visibility. Im...
2,082
Hy guys ! I've been making some projects in this easybuilder pro for weintek HMI, and i am struggling with a tiny problem but i can't seem to...
2,825
I converted a Maple Systems EB5000 Project from a discontinued screen into a EB8000 Program and from there to a EB-Pro I have a MT8012iE screen...
2,005
