Easy Builder 8000
roxusa
Nov 2008
NJ
994
I am using EB8000 building displays for machine temperature readouts and all is working fine. I recently incorporated one into a process machine to reead a lot of data that was already in machine and only accessible through a DTAM that you had to scroll around on. All is pretty straight forward my question is running this screen in my office to test (ethernet) I get a periodic "PLC no response" on the screen and then it will go away without hitting the close button. I feel this may be one of the integer files it is looking for is missing but I haven't been able to find it. I have not worked with the Weinview/Weintek screens or software that much and am in the process of familiarizing myself with all of its features. Is there a way to find a missing input or output without going through each one. I know in AB's Panelview Plus the info. bar automatically tells you the address it cant find, then you have to hunt for that one screen by screen (been there) Thanks
I use Easybuilder Pro, and had a similar issue a while back.
I could not find a way to find missing tags, other than to go through all the objects on the affected screen(s).
Hello all Kindly I need to know how to make online simulation between easybuilder 8000 (weintek) and s7-200 plc Which cable type is required...
1,751
Hello Friends; I use FX1N-14MR PLC with 6070i 7 inch display HM. I design the screens and create tags by using tag editor. But PLC not response...
2,858
Hey All. Im using Easybuilder pro. Im familiar with using the enable/disable function of the security tab on an object to use visibility. Im...
2,084
Hy guys ! I've been making some projects in this easybuilder pro for weintek HMI, and i am struggling with a tiny problem but i can't seem to...
2,831
I converted a Maple Systems EB5000 Project from a discontinued screen into a EB8000 Program and from there to a EB-Pro I have a MT8012iE screen...
2,007
