Easy Builder Pro Question
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey All.
Im using Easybuilder pro. Im familiar with using the enable/disable function of the security tab on an object to use visibility. Im wondering how to set visibility to a group of objects.
Im not seeing this, is it possible or do I have to apply the visibility to each component of the group?
Not sure what version you are using, but the latest allows you to select multiple objects, right-click, then select 'Security Settings'.
See attached.
Rob
I'm using version 5.07.
When I group objects together and right click, security is not one of my options.
I can go to attributes and see the names of each object in the group, then there is a button in that window for settings...... oh oh and now I have figured out where to find security and therefore now know where to set enable/ disable for he group.
There you go. Just like that:beerchug: I can now set enable/disable (visibility) to the group of objects.
Thanks PLC.NET
Hy guys ! I've been making some projects in this easybuilder pro for weintek HMI, and i am struggling with a tiny problem but i can't seem to...
2,826
I converted a Maple Systems EB5000 Project from a discontinued screen into a EB8000 Program and from there to a EB-Pro I have a MT8012iE screen...
2,005
Hello all Kindly I need to know how to make online simulation between easybuilder 8000 (weintek) and s7-200 plc Which cable type is required...
1,745
I am using EB8000 building displays for machine temperature readouts and all is working fine. I recently incorporated one into a process machine...
1,657
Hello Friends; I use FX1N-14MR PLC with 6070i 7 inch display HM. I design the screens and create tags by using tag editor. But PLC not response...
2,857
