Some one Member S Join Date Jun 2020 Location Egypt Posts 10 Jul 26, 2020 #1 Hello all Kindly I need to know how to make online simulation between easybuilder 8000 (weintek) and s7-200 plc Which cable type is required and the steps
geniusintraining Lifetime Supporting Member + Moderator Join Date Jun 2005 Location SC Posts 8,278 Jul 26, 2020 #2 I think it depends on the PLC and port you are going to connect to This may help https://dl.weintek.com/public/PLC_Connect_Guide/Siemens_S7_200_PPI.pdf You can also go to this page https://www.weintek.com/globalw/Software/EasyBuilderPro.aspx Click PLC on the right side in the blue bar, scroll down and select Siemens AG, then your PLC model (S7-200 or smart) then select your driver then download the PDF
