EasyBuilderPro GetData Syntax
nrwicks
May 2010
Wilson
When using the Siemens S7-1200 Symbolic Addressing driver, there is no Offset Tag or Index Option
I wish to be able to read an array tag for different array element values, for example
"PLC.Blocks.Data.Dev[0].HMIModeReq"
to be replaced by
"PLC.Blocks.Data.Dev[Index].HMIModeReq"
Is there a method of replacing "PLC.Blocks.Data.Dev[0].HMIModeReq" with a string tag that I can build with the Dev or Index number between the square brackets [ ] number that I wish
The application is a popup window that needs to read and write the Dev number tags for the device that is selected
Thanks for your help - Neil
Hey All. I have a series of screens I use in EasyBuilder Pro. I made set for a UDT and AOI that I use in my Compact Logix processors. The...
4,305
Hi all. I'm building my first Grafcet using Logix, but I started from another project. From what we usually do with other PLC's, I was expecting...
161
Hi. I'm struggling over some basic stuff here. 41001 I is a 16 bits integer that I'm able to read with InTouch. What I need to do is to read...
96
Hello, Im new to Studio 5000 View Designer and i try to make a popup reusable screen. So i create a user-defined screen with 2...
250
Hello, Which syntax I need to use for write on value on a “local tag” that have “Machine” as scope? Thanks
444
