Eaton SVX 9000 AFD RS232 Configuration
Deanna
Sep 2011
Oregon
I need the pin configuration for downloading parameters to the Eaton Cuttler Hammer SVX 9000 AFD. I am not sure what configuration to use. Can anyone help me with this
I hooked up yesterday. Used a pin for pin (male one end, female other end). Unhooked cable going to door display and hooked up my pin for pin cable to that cable.
Do not use a standard serial cable
The drive serial port has power on some of the pins for powering the display. This can damage the serial port in your computer. Only 3 pins are required for communications. You must cut off the other pins or build a custom cable. See the attached document for instructions.
software
Sorry to wake up a very old thread. I am new to PLC programming and we have an SV9000 in the facility. What software would you recommend putting on my computer to program the controller. Sorry if that was not worded the best, as I said I am New
John
SvTool software
My turn to be sorry for waking up that thread too. I am searching for that SvTool software. Does anybody have it?
I have Eaton SVX 9000's controlled via devicenet by Emerson Delta V. My drives keep reverting back to requesting a local reference after they...
1,425
Well...let me try this.... Problem : When troubleshooting an existing SVX 9000; with the load ( submersible pump ) disconnected....we are...
4,548
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
129
Hi everyone: we have Baumuller AC drive BM4463 300A 160KW, it drives Baumuller AC motor DST2-315BO54W-020-5-A (90KW;RPM 200; 365V; 215A;83Hz)...
369
Hello everybody, Since my experience is mainly with AB ladder I am having little bit of a problem with EasySoft.. Does anyone knows is there a...
843
