EB Pro, Register Index/Offset help
theColonel26
Feb 2014
West Michigan
785
My base address all work fine. The problem starts when I set the Index from 0 to an offset. I get a "PLC No Response" error.
So say my Base address is B10:2/5
In maple that address is 01000205
What if I want to access B20:2/5
Would that offset be 10,000 or would it be 1,000,000? the Manual says that offsets for bits are still by words, so I would think the offset would be 10,000 I have tried both. I get a "PLC No Response" error with both.
if I assign If I set it to use Index 16, and set index 16 to 10,000 I would expect to get B20:2/5
Same for words if it was F15:4 and I wanted F25:4 I would set the index to 10,000 and if I wanted F35:4 I would set the index to 20,000 as 015,004 + 20,000 = 35,004
and N at the Bit level N13:2/8 to get N42:2/8 I would need to use 30,000.
What am I doing wrong?
For Bits the index is a multiple of 16. Search "INDEX_REG_DETAILS" in the help file.
But this would only work on a single file of 255 elements. Your using separate files.
Normally the offset would be B3:10/5 x index of 10 or 160 bits which would be B3:20/5
B3:10/5 could be entered in you PLC as B3/165 or enter B3:20/5 as B3/325
Which breaks down as File #: Word x 16 + Bit
if you want to use separate files. then you'll need to map your B# files to LW and use the LW in your HMI to mirror your B# files in the PLC.
Use the Data Transfer (time base) of B10 -> LW10 and B20 -> LW20 and use an index of 10.
I am having trouble with creating a shift register in Unity Pro on my Schneider M340. I am using the FFB SHR to try and get this to work. I have...
5,081
Hello, I am trying to modify the MBP_MSTR FB in order to write data to another thirty part device. Could you give me an example (which working)...
2,515
Hey guys; Im in between projects at the moment and I decided to mess around with Unity Pro XL as it will be the next PLC used on my next...
9,006
Hi, I'm working on a project and building a dfb. What I need is the address-register of a variable and using it for a start-adress. (see...
2,156
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
37
