Hi all,
I have been attempting to create an EDS file for a simple earth leakage relay, not many inputs and even fewer outputs. I am using the EZ-EDS program (https://www.odva.org/subscriptions-services/software/ez-eds-download/) to create the file.
I am stumped as to where the ConnectionN Path field comes from and how it is determined. I am currently using a generic path I appropriated from a Rockwell sample EDS file (see attached). Creating a module using this EDS in RSLogix 5000 produces the error seen in the attached screenshot.
EZ-EDS provides a popup (see attached) with pop up fields to fill out to generate a path, but I'm still unsure about what to put in this fields.
Has anyone created an EDS file before and could shine some light on what the error means and how to properly determine what path I should be using?
P.S. I have attached the EDS file I have been working on (currently a .txt file).
