Edwards Signaling Horn 5532M-AQ
waterbottle
Mar 2019
Florida
42
Hello forum,
I'm trying to install a edwards signaling remote speaker amplifier horn. The purpose of the installation is to trigger an alarm when machine is not running. The issue is that I cannot see a way of how to select the tones on the horn or if I need to purchase a separate module for those. Im use to see the dip switches to select the tones but this model did not have them. If anyone has installed one of these before and can give some advice it will be helpful.
Model 5532M-AQ
Remote Speaker Amplifier, Continuous Sound Pattern, 24VAC/DC Voltage, Decibels: 100dB, Color: Gray
https://www.grainger.com/product/EDWARDS-SIGNALING-Remote-Speaker-Amplifier-16G663?cm_sp=solr_search_page-_-Products_You_Have_Recently_Viewed-_-AZNSZ_P-BackupNullRecs-100719&cm_vc=AZNSZ_P-BackupNullRecs-100719&req=Products_You_Have_Recently_Viewed
Hello All, I am helping a Water Treatment Plant troubleshoot signal issues with their Schneider Electric PLCs. They have an M580 PLC (PLC-A)...
1,584
Good day all. I have to ask about signaling devices. In this new plant we have MANY horns, buzzers, strobes and stack lights. The signal for all...
22
8,115
I am recieving a 4-20Ma signal from a peice of equipment. This signal however has only 14 volts and I am getting nuthin. I am putting into an...
1,728
Hello to all! Does anyone know of an infared device which is communicating with a PLC? Not sensoring devices but something simular to a...
19
4,766
Hello, I have a recordable horn I am trying to drop some .mp3 files into. Part no. 856T-BH3. It requires at a USB A 2.0 to Micro USB. I have used...
2,063
