DickDV said:Dan, the more I think about this, the more I am convinced that the equivalent of an ICE throttle is an analog torque input to the drive. Proof of this is to hold your foot stationary on the throttle and watch what happens to speed on a hilly road.
If simplicity and similar drivability with ICE is desireable, I would forego the complex electronics and simply use what gas engines use now- the driver's brain controlling the pedal to regulate the torque. Of course, you could set max torque limits.
As kamenges mentions, if you did use speed regulation, it would have to be very very soft. Otherwise, every movement of your foot would cause a full-torque speed correction to match and the result would resemble a bucking bronco. Also, only slight lifting of the foot would cause full regen braking---kind of like that bucking bronco running into a wall!
An ICE does produce a little engine braking when coasting and that could be done again as kamenges mentions. However, it seems to me that the throttle braking would only be slight, maybe 10%. More than that would have to come from the brake pedal. Exactly how to implement such operation would take a little study especially when mechanical braking is blended in at heavy brake pedal pressure or slow speeds.
Hmmmm! Cause for thought!
DICK
Keep thinking. The idea of course here is to get it started to say 2 or 3 mph and then the foot throttle (potentiometer) would have control (or to put it more accurately at less than 3 mph the start ramp would override control.
The jerky foot on the throttle would be a problem. The factory recommends a hysterisis band such that minor positon change on throttle would not jerk you.
At this time I intend to basically use speed control and ramps for changing motor (vehicle speed). Since the VFD gives me 3 dash controllable / selectable ramps AND they give me torque limits that can be set AND they give me power limits that can be set I am going to go this way. Will take some experimentation I know to set the speed ramps then the torque limits and then the power limits so they are not constantly conflicting but I guess that is what a learning curve is all about.
I have been righteously called the King of Overkill by my brothers and I realize I tend to make things a little too complicated. I learned the electrical trade as a nuclear submarine electician so cmplicated systems are something I grew up on.
Many thanks to all of you for being good devil advocates.
Dan
