locotumbler
a little back story on my machine.
It is a cut to length machine running via a Zeta 6104 controller. the encoder is operated by the 1/2 round wire being pulled over the steel shaft. the downward force is generated a spring loaded lever. the actual part pushing down on the wire is a bearing with a grove in it so as to keep the wire in place.
Problem I have is that over the run and when i shut it down and run again is that the wire shrinks in length so I have to go in and increase the total number of counts in order to achieve the correct length.
the encoder is a 1000ppr encoder. the shaft is .315" in diameter and the parts are 13.17" and 13.5" in length.
for the 13.17" rod i have my counter set to 54030
for the 13.50" rod i have my counter set to 55450
I have encountered issues before where i start losing counts on an encoder but when that happened my rod length began to grow as it needed to pay out more to meet the count level. Have any of you ever encountered an issue where an encoder causes parts to shrink in size. i.e. its putting our MORE pulses than before?
the encoder model E151000A865
